跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
873 个问题 查看全部
Case marks/spots on rear glass
Has anyone found a way to removing/buff out these spots off iPhone rear glass?
It is not scratches or marks for sure. It is clear that these appears because of the use of a bad case, because they seem to disappear right at the edge of the camera hole, where a case is not pressing against the glass.
i have tried acetone and 99% isopropyl alcohol without any results. maybe some glass polishing stuff like for cars would help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
applying isopropyl and acetone can damage the oleophobic coating and also the gaskets that make your phone splash proof.
i had tried many household items, with no luck removing the scratches.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tubbe Lenbroch 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 72
总计 4,043
