跳转到主内容
Are MBP A1150 and UMBP fans physically the same?
I have a A1150 MBP its old but does the job,
i replaced the screen with a 1680*1050 screen
but thew rest is stock
the mbp runs hot and the fans are half dead
they go to 3k rpm and make crunching noise (something is broken there)
anyway
i checked ebay and the fans look identical
physically
but i read the connector is different
it not a problem to re-solder the connector
so the question is, are they PHYSICALLY the same?
ie the distance between the screws and the WHL dimensions
thanks!
ps: i would just repalce them if i had a spare UMBP :)
also the price is about 10$ lower than the old fans
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
Not a direct answer to you question, though a direct answer to your problem. Peel back the paper on your fans and put a drop or 2 of 3-N-! oil in the exposed hole. Reseat the paper covering and/or put a piece of tape over the fan bearing. I have repaired hundreds of noisy computer/laptop fans this way.
这个答案有帮助吗?
得分 4
1条评论:
Cost Effective +
完成的
添加一条评论
Just get the correct part. You're going to have the wrong connector and after soldering the old one on it may not work. Personally I put in new fans as the used ones on eBay usually already have a lot of use already.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
meim 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 570
