跳转到主内容
MacBook Pro Core 2 Duo Models A1226 and A1260
My Macbook Pro A1226 will boot with a chime and go to a blue screen with a horizontal white line in the middle then proceeding to a vertical gradient of blue after completely booting.
I have tried safe mode, reinstall and everything else I have read on the issue.
I even tried command shift 3 to see what it would do and heard it take a screenshot.
Could it be a bad inverter board? A couple of days ago I noticed the screen wasn't as sharp as it used to be.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
These models have the Nvidia 8600 GPU. There is a recall on this if it is the problem. Please give us the last three figures of your serial number so we know exactly which machine you have. Hook it up to an external model and see if the problem persists. If you're close take it in for Apple to test for this issue.
这个答案有帮助吗?
得分 5
4条评论:
+ mayer is correct here. Your issue is more than likely with the GPU. You have a LVDS (Low-voltage differential signaling) issue here. Your problem is either in the video circuitry on the motherboard/logic board or a TAB fault (Tape Automated Bonding) on the actual LCD.
完成的
Thanks Mayer, the last 3 figures of the serial # are YAM. I was trying to take care of the issue myself to avoid the charges from Apple however, it sounds as if there is no choice.
By "recall" does this mean even though the machine is out of warranty I may get a free fix?
I bought this machine as a secondary for one of my employees to use and it worked fine for 3 weeks. I noticed a few days later when he was using it that the display did not look as sharp & crisp as when I purchased it. I guess sometimes a "good deal" is not always a "good buy".
完成的
Actually William, in this case, recall means Apple pays for the repair whether you are the original owner or not. This could turn out as a good deal being an excellent buy.
完成的
Apple MacBook Pro "Core 2 Duo" 2.4 15" (SR) Specs
Identifiers: Mid/Late 2007, 2.4/2.2GHz* - MA896LL - MacBookPro3,1 - A1226 - 2136 This has the Nvidia 8600 processor.
Here's where to contact Apple for your free logic board repair: http://support.apple.com/kb/HE57
完成的
添加一条评论
I have the same problem. How is it to fix it yourself? Do I need to replace the logicboard?
这个答案有帮助吗?
得分 0
添加一条评论
I have the very same problem, I contacted Apple and they said they would only do the repair work for free if the machine was under four years old, no exceptions. Mine was four years and two months and they would not entertain it. The best of it is that had I been made aware of the problem by Apple who obviously knew about it, it could have been done under there scheme when it first started to show signs of the fault a year earlier!!! Apple could have contacted everyone who bought a machine like this via email which they will have obtained when the machine was registered with them, very simple!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
William Weavil 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 2,991
