跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Charger port replacement compatibility
So last year maybe around August I had got my laptop repaired by Apple and by November it’s was damaged in the same place. So I need to know what charger port replacement would be compatible with my MacBook model a1502?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I’m suspecting you have a more basic issue here. While you may need a new port connector as well the root issue is the bad/fake MagSafe charger that’s damaging your system. Here’s the best source for the replacement charger Apple 60W MagSafe 2 Power Adapter (MacBook Pro with 13-inch Retina display). Anything you find on Amazon or eBay is Fake!
I would inspect the systems MagSafe contacts often I find them blackened from the arching. Also inspect the while plastic for debris as well as the pins in the cord.
In this picture the top connector is dirty and needs to be cleaned.
Here’s the needed part 13” Retina MacBook Pro DC-in, Magsafe 2 board, Apple P/N 923-0560 and the guide 交换MacBook Pro 13" Retina显示器2015早期版本的MagSafe DC-in板 to put it in.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rebecca 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 1,128
