跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Why does the MacBook Pro doesn't boot up? (after top case replacement)
Hi!
I have installed a new topcase on my Macbook Pro (a1278) mid 2012.
Before installing it, the computer worked fine without a keyboard (I would usually remove the battery and power it on with the magsafe cable, since the keyboard wasn’t working).
Then I replaced the topcase (with Keyboard, no trackpad) and now the computer doesn’t turn on.
I tried powering it on with the magsafe and even with the Logicboard’s power pads and nothing.
I have attached a picture in case anyone has any suggestions?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This has been fixed after I put the rear/bottom case back on the MBP.
I assume I had a cable poorly connected and it seems that puttng everything together solved it!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Your photo shows the battery is not plugged in.
这个答案有帮助吗?
得分 1
1条评论:
Yes I know :) I was turning the computer on with the magsafe only
完成的
添加一条评论
添加你的答案
Manuel 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 108
