跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Where is the keyboard connector located on the board?
Hello everyone. I have a Macbook pro a1708 with a non functioning keyboard. The machine can fire up using the power on button, but the rest of the keyboard or backlight doesn’t work. This happened after the computer went in for a water repair. That is why i am thinking that the techinician didn’t put the keyboard connector on properly. Does anyone have a picuture or illustration that shows where the keyboard connector(s) are/is located?? Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
We don’t have a guide to take the logic board out or replace the keyboard but we do have enough images to see where things are.
First, after taking the bottom cover off following this guide: 2016末期13寸 MacBook Pro 功能键版本的底壳更换
Locate the Right fan (on the left side from the bottom). Lifting the speaker off that surrounds it you’ll see the keyboard cable below it
And here a close-up of the cable
Sadly, the keyboard is riveted in and difficult to replace. I would strongly recommend you just replace the full uppercase with a new keyboard then trying to salvage the uppercase. Here are used parts which will work
US:
UK:
这个答案有帮助吗?
得分 3
3条评论:
Thank you very much Dan!
完成的
Did adjusting the cable solve your problem?
完成的
@chris51297 - Replacing the cable was the first solution if there is corrosion on it. Otherwise its likely a messed up keyboard which is a bear to change out. I would recommend replacing the uppercase as I outlined
完成的
添加一条评论
so I was able to find and remove the cable. Prior to that the power button was working fine. Once I replace the cable now neither the power button nor keyboard work. What could I have done wrong?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Christian Aarup 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 52
过去 30 天: 204
总计 11,524
