跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Randomly turning on without touching.
So my phone got dropped in waster yesterday and now I have it next to me and it randomly keeps turning on and off but when it turns on it goes to Siri?
HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The iPhone 6 screen is not glued down. The phone opens from the bottom and folds up, just like an old flip phone. Don't bend it to far or you can damage the cables, they are very fine and easy to tear. The first thing you need to do is unhook your battery. Back it up if you can, if you can't hopefully iCloud has it stored there. If you got it really wet I am not going to lie to you, but your chance of fixing it even if you are willing to pay for it are slim. The iPhone 6 has no seals and water will just flow in and the moment it gets wet with electricity going through it, it begins to corrode. As soon as it happened you should have disconnected the battery and definitely not hooked up to charger (hopefully you didn't). But most likely it's not worth fixing. I know the best of them will only do data recovery only if it's water damaged. Sorry for the bad news. Hopefully you will get lucky.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, definitely backup your data first, but you could try following iFixit’s iPhone 6 Screen Replacement tutorial, and disconnect the home button connector. Gently clean it, the home button, and any other spots of water damage with a brush soaked in rubbing alcohol. Try testing it out without the home button cable connected
If this is your first time disassembling an iPhone, be VERY careful!
这个答案有帮助吗?
得分 0
1条评论:
Did you have any luck?
完成的
添加一条评论
添加你的答案
Lily 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 61
