跳转到主内容
The 2013 revamp of the desktop Mac series known as the Mac Pro.
OWC SSD shows as external drive under Startup Manager
I’ve installed a new 1TB OWC Aura Pro X2 SSD in my 2013 Mac Pro - I’m running Catalina and formatted the SSD with APFS. It’s working pretty well aside from some odd issues. When I boot with the option key to run Bootcamp I will often get a chime and then nothing at all, just a blank screen. I then have to force a shutdown and try again. Usually on the second or third try I’m presented with the Startup Manager screen which shows two external disks - one is “Aura Pro X2” and the other is “EFI Boot”. Obviously these are both on the internal SSD and usually are labeled as “MacOS” and “Bootcamp” or similar. So I get the feeling something is not quite right. Has anyone had this issue with their OWC SSDs?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Similar issue on a MacPro 2009 using a PCI adapter card with an OWC 2.5” SSD mounted to it. It showed as an external drive. OWC has a page of hard drive icons, so I changed it to look like what I am running.
On not booting correctly, go into system Preferences > Startup Disk > unlock it > select the drive you want to boot from. See if this solves it.
这个答案有帮助吗?
得分 0
1条评论:
Strangely my Bootcamp drive icon shows up on my desktop, and in Disk Utility. But if I go into Startup Disk as you suggested, it doesn’t appear at all. The only choice in the Startup Disk pane is the ‘Macintosh HD 10.15.4’ disk.
完成的
添加一条评论
添加你的答案
Crispin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 245
