跳转到主内容
商务笔记本,HP公司2014年推出,型号:M0X64US#ABA(译者注:莫名其妙的型号,大公司通病)
3 个问题 查看全部
Laptop not switching on with battery sometimes
My laptop switch on when connected to power. If you don't use it for about 5 days, it can switch on on battery. When it's in power, it does not charge the battery more than 76%.
So sometime it works on battery and sometimes it doesn't. What could be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do you know if the battery is original? This was released 6 years ago and most PC batteries last 2-3/4 years.
If you can get it to start without the battery, one of the cells is bad. Refer to this guide to disconnect it and see - that should be sufficient for troubleshooting unless it has to come out due to it’s design.
这个答案有帮助吗?
得分 0
1条评论:
Thank you for your quick response.
I bought this pc from ebay UK.
I ordered a brand new battery after this problem started. But the problem is still there
完成的
添加一条评论
添加你的答案
Kumbirayi Chitauro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 164
