跳转到主内容
20", 23", 和 30" LCD 显示器 发售于2004 于 2010年停产。
99 个问题 查看全部
Mac sees the 20" Cinema Display but display is black
The Cinema Display’s Indicator light is also black. The mouse of my MacBook Air 2017 disappears to where the monitor should be so the computer is seeing it, but the display otherwise appears dead. Is it time to give up on my old friend or is there a repair?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I think its wise to get a new monitor as you can get a larger screen with better image quality for around $200 used.
This display uses CCFL’s and uses the older dual-link DVI connector system which besides being clunky won’t support 4K or 5K if you really want to push things.
这个答案有帮助吗?
得分 1
2条评论:
I’ve ordered a replacement monitor but I am still interested in trying to fix the Cinema Display. I’ve found similar issues in similar threads that indicate the fix may not be too expensive but I’ve not found enough detail to attempt a repair or order a part.
完成的
I did a bit of looking for the likely needed parts. I'm sorry to say I just couldn't find any. The only thing I can suggest is searching the used displays to see if you can find one for parts.
完成的
添加一条评论
添加你的答案
Keleigh 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 4
总计 122
