跳转到主内容
Model A1200 with 2.16 or 2.33 GHz Core 2 Duo processor
113 个问题 查看全部
Is this possible to do? Planning on turning iMac into monitor
I’m planning on turning this 2006 24 inch iMac into a monitor for another computer and I’ve bought the LVDS controller board and it needs 12V power so I bought an adaptor to use the original iMac power supply by connecting the SATA power cable to a DC In Cable to power the controller board but i found out the inverter which is part of the display needs 24V of power separately and i don’t know how to give it power? So I was planning on possibly using the original motherboard of the iMac and connecting it to the inverter which is how it was powered in the original computer through a cable. Could I do that? Use the controller board to control the LVDS signal but have the original iMac motherboard power the backlights through the same cable it did originally in the computer? I would have to press the power button and all so the computer thinks it’s on and powers the sata power and inverter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
This system uses CCFL lamps for the backlight unlike newer ones which use LED.
There is a inverter which requires the 24 volts and then bumps it up from 200 volts to more than 600 volts at a high frequency. The lamps are no longer available so if the display is dim there is nothing you can do to fix it.
You may want to look for a newer system to convert.
这个答案有帮助吗?
得分 1
添加一条评论
Here’s a pictorial guide on how I did it:
How to build a display using a iMac
这个答案有帮助吗?
得分 1
1条评论:
@mayer - Missing a lot of that wisdom you have ;-}
Can't wait to see this finished.
You also have some other stuff mixed in at the end, it looks like both MacBook Pro TB and MacBook display disassembly.
完成的
添加一条评论
添加你的答案
Teddy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 18
总计 110
