跳转到主内容
加入维修社区 - 创建账户
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Why can't I seat display cable
I bought a second LCD display because I thought I may have done something to the cable end coming into the unit. It doesn’t seem to be it. I’ve no power at all to the LCD though I have an external display, not only is no power reaching it, it isn’t recognized by System Preferences. This is my first MacBook repair. Any and all tips appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Can you take a few pics so we can see what you are encountering, post them here 在已经存在的问题里加入图片
完成的
添加一条评论
1个答案
已选择的解决方案
Sadly the socket was damaged somehow. It looks like someone pulled straight up Vs sliding out the tang to the side as outlined in the guide MacBook Pro 15" Unibody Mid 2010 Display Replacement as stated in Step 15.
Sadly its time for a new logic board as being the easiest fix, otherwise you’ll need to find someone with the needed skills and tools to replace the connector, but that still assumes the logic board is good, that’s a large gamble here.
2010 15” MacBook Pro Logic Board 2.66GHz i7, Apple P/N 661-5480
2010 15” MacBook Pro Logic Board 2.8GHz i7, Apple P/N 661-5803
Here’s the guide you’ll need to follow to install it: MacBook Pro 15" Unibody 2010晚期逻辑板更换
MacBook Pro 15" Unibody Mid 2010 逻辑板图片
指南
难度:
困难
30 minutes
MacBook Pro 15" Unibody Mid 2010 Display图片
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 2
1条评论:
Thanks ! The dummy was me ! Iswore I came out parallel to the board, but either i did pull up or my explorations wounded it.
I'll follow the links to check prices, but I need a part # for the connector just in case. The rest of the system is fine.
完成的
添加一条评论
添加你的答案
James Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 82
