跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
Trying to find part# for the logic board
Serial# is C02V290RHV2L (2017) Model-A1706. Have to replace the logic board but have no clue how to shop without the part# anyones help I would be greatful. Apple wouldn’t give it to me.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
Please tell us why you want to replace the logic board as i may have an alternative.
完成的
All 3 lightning ports were not working. Took it to a local repair. replaced battery, bought new charger. He first said some chips needed replaced now replace the logic board. In all, the computer will not turn on with or without charger.
Thanks
完成的
@chumppunk - Have you tried going directly to Apple? Where do you live?
完成的
I'm in Gulfport, MS I called Apple I was just trying to lower the expense and buy one. Just can't get correct Part# to shop.
Thanks
完成的
OK, what is your config CPU, GPU, RAM & Storage? If you go to About this Mac you'll find most of it there.
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
i5 3.1 GHz 8G 256GB - Apple P/N 661-07648
Frankly, if you are going this far you might as well also look at upgrading your RAM and Storage as both are on the lean side for anything more than writing, web browsing, watching & listening to content. If you can swing it look for this one:
i5 3.1 GHz 16G 512GB - Apple P/N 661-07664
I would also strongly recommend you get a good surge suppressor or better yet a UPS if you are not that mobile. You should use the Apple charger and the cable that came with it. I’ve seen a few systems damaged when other chargers are used and cheap cables that are not designed to handle the wattage of the charger.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 132
