跳转到主内容
加入维修社区 - 创建账户
Repair and disassembly guides for GE Microwave ovens.
GE Profile Micro Crazy
GE PEB9159SJ1SS, 2016, turntable was working, food heating. Now turntable spins, no heating, then turntable doesn’t spin , sometimes food heats. Lately the only constant is if turntable does not spin food does not heat. Right now nothing works, turntable, heating, convection, broil. All the touch pad buttons working.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi @stavroula ,
Check if the door interlock switches and latch -part#20, 21, 22 & 24 are OK and working. They may have worked loose or the latch is bent/broken and are not operating/releasing when the door is closed.
Be safety aware when working in a microwave oven as they can still be extremely dangerous to work on even if the power has been disconnected. The HV capacitor need to be discharged correctly before working in a microwave
Ensures the microwave operates only when the door is securely closed by detecting the door's position.图片
产品
GE Microwave Door Interlock Switch - WB24X10146
$46.99
Detects and responds to specific commands within the microwave system.图片
产品
GE Microswitch Monitor - WB24X10190
$48.99
Supports the door switches in your microwave to ensure correct function.图片
产品
GE Microwave Door Interlock Switch Bracket - WB14X10049
$43.99
Engages and disengages the microwave door mechanism through a lever action.图片
产品
GE Lever Switch - WB10X27080
$36.99
这个答案有帮助吗?
得分 0
2条评论:
Door, all latches working correctly.
完成的
@stavroula ,
Juts being pedantic, but did you test the switches with an Ohmmeter to prove that they were operated (and released - one is NO and the other is NC type switch) when the door is closed or just prove that the latches moved the switch(s) actuator?
完成的
添加一条评论
添加你的答案
Edward Vozzella 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 131
