跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Touchpad and keyboard not responsive
Hi guys,
My touchpad stopped and keyboard stopped working about 3 weeks ago for a few hours and were completely non responsive however just randomly started working again.
This happened twice and then since then it hasn’t worked at all. I adjusted the trackpad cable (while I was waiting for the new one to arrive in the mail) which also fixed it for a few days, and then it stopped again.
Unfortunately did not work with the new trackpad cable which I was sure would do the trick as this seems to be the solution for this from my research.
What else could the issue be? Has worked completely fine with external keyboard this whole time. Thanks in advance!
Edit: Coconut battery screenshot added
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Lets check the battery as your symptoms sound like it is swelling. First lets get a better look at the batteries health, install this gem of an app CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片. Then lets inspect the battery, when the system is encountering problems carefully remove the bottom cover and compare the battery to the images in this guide MacBook Pro(13 英寸,配备 Retina 显示屏2015 年初期)电池更换 Jump down to Step 18 for a good image do all of the cells look OK?
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
MacBook Pro 13" Retina Display Early 2015 电池图片
指南
难度:
困难
45 minutes - 2 hours
这个答案有帮助吗?
得分 1
2条评论:
Thanks for the reply Dan! I have attached the image to the question. Looks fine to me. Do you think that maybe the touchpad would need to be replaced?
完成的
添加一条评论
添加你的答案
tom.mcmahon77 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 59
