跳转到主内容
My screen keeps flickering and I am having problems booting.
Hello, i have a 17 Inch MBP (non-unibody) model A1229.
First, when i boot, i get these two black bars on the edge of the screen, and the spinning wheel on the boot screen had frozen. Here's an image
I had followed the instructions on this page
So i was able 2 boot the MBP. However then i had noticed that the screen was flickering incredibly fast (about 3 times per second) and the computer was unresponsive. I think it may be the graphics card, however i am not 100% sure. Please help D:
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hook your machine up to an external monitor to test out the graphics card. There are several things on your link. Which one did you use to be able to boot. You may be having more than one problem. Try booting from your system installation disk and let us know your results. Please give us the last three figures of your serial number so we know your exact machine. There are about 10 models in the A1229 line. Also, can you give us a history of any problems this machine has had?
这个答案有帮助吗?
得分 2
添加一条评论
I had this problem after replacing the screen on my Macbook Pro A1261. When I 'zapped' the PRAM Battery it solved this – Turn off Laptop, hold down - alt, cmd, P and R buttons and press power button – hold down until mac turns on, turns off and then restarts again.
**I found other key combinations to use on older macs to Zap PRAM are Shift,Ctrl,Alt and power buttons,
Seán
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tristan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,010
