跳转到主内容
Is Galaxy s10 plus replacement screen waterproof?
Or should I buy silicone around the corners ?
I’ve seen some people changing the whole front screen, taking out the battery and placing into the new screen. So the new screen should have adhesive inside already?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
No phone is 100% waterproof to begin with. If you want to change the screen and frame buy a samsung service pack as it will be the same as factory.
这个答案有帮助吗?
得分 2
2条评论:
What happens if you do not use adhesive to stick the screen back on?
完成的
It won’t stick
完成的
添加一条评论
Samsumg S10 display replacement water proof yes ya
这个答案有帮助吗?
得分 0
1条评论:
No it’s not waterproof
完成的
添加一条评论
You can buy a replacement screen aftermarket, get it with the frame. It will be waterproof if you reseal the back cover. But that depends on how good your work is. You. Have to take the back cover off to take the phone apart to replace the screen. So it all depends on who puts it back together and if they seal it correctly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abbe 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 6
总计 3,956
