跳转到主内容
iPhone 3G是第二代iPhone。型号A1241,有8或16 GB容量,和炫酷的黑色或洁白的白色塑料背面。修复比第一款iPhone更简单。需要螺丝刀、撬撬工具和吸尘工具。
Why can't I turn the phone on?
I took the front off of the phone to place the 1 tab back into position as I was getting a white screen issue. After putting the phone back together I couldn't get it to turn back on. I didn't even fully take it apart, only lifted the screen long enough to put the tab back into place. Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
添加一条评论
6个答案
最有帮助的答案
check that the lock-switch connector is on fully, as there may be no hardware failure, but somthing preventing you from turning it on.
这个答案有帮助吗?
得分 2
3条评论:
Where is the lock-switch connector?
完成的
Where is the lock-switch connector located?
完成的
Om the right corner o.
完成的
添加一条评论
i think my phone have hardware problem
Update
please show me phones diagram
这个答案有帮助吗?
得分 2
1条评论:
gayan, it would work so much better if you ask your ow Click on the link on the right side of this page. "Ask a question" and give as much detail as possible.
完成的
添加一条评论
my samsung s4 is not working it fell the screen cracked and the mother board not working i cant switch it on
这个答案有帮助吗?
得分 0
添加一条评论
wen i turn un my phone it stop by the starting tone
这个答案有帮助吗?
得分 0
添加一条评论
why cant my phone turn on
这个答案有帮助吗?
得分 0
添加一条评论
My G3 Phone can not on
这个答案有帮助吗?
得分 0
2条评论:
完成的
Please what shall I do?
完成的
添加一条评论
添加你的答案
shannon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 2,142
