跳转到主内容
Model number LS676 for Boost and Virgin Mobile.
How to fix a wet phone with many problems
I accidentally let my phone fall down to the toilet I quickly dried or I thought I did but later while just leaving it be I saw water on it so I cleaned it again but I have four problems you can’t hear anything and when it’s off it makes buzzing sounds as if it was turned off then on and when you turn it on it will only last for a few minutes then it turns off saying over heating and it wont tell me how much actual battery it has it only stays in 100% all the time but clicking and WiFi, searching everything else is okay how can I fix the other problems though?"
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
4条评论:
Okay having another problem now it has a bright spot on the edge like splattered water I don't think I dried correctly but it's already really in what I do I don't want to loose my phone
完成的
@Abril Santana ,
Didn't you read the answer to your first question that you posted earlier?
完成的
I spilled water on my LG Tribute Dynasty MODEL is LG-SP200
完成的
@mylg Take a look below at @jayeff's answer on water damage to electronics. Turn it off and clean it properly to save it. Good luck!
完成的
添加一条评论
1个答案
此回答最初是针对另一个问题
Hi
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion is ongoing until it has been properly cleaned away
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion etc. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here’s a link to the ifixit LG Tribute HD repair guides which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abril Santana 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 10
总计 208
