跳转到主内容
A lawn mower made by the American Company Toro
117 个问题 查看全部
Spitting Oil out Exhuast when starting
Went to start my mower today and when I pull the chord to start it, it just knocks and a puff of white smoke comes out. I also realized that there is oil, a good amount, dripping out of the exhuast. It's been sitting right side up, never turned over, so I'm at loss for what to do. Any info anyone has would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would say you flipped it and that’s why you’re getting that but it could be a gasket try checking the gas for oil
这个答案有帮助吗?
得分 0
1条评论:
Its sat for the winter and I haven't touched it. There isn't oil in the gas. I just put gas in it for the first time this spring. Didnt want gas sitting in it while not being used.
完成的
添加一条评论
Most likely is that you are overfilling the oil. Second would be leaking piston rings.
这个答案有帮助吗?
得分 0
2条评论:
I haven't put oil in it this year since the spring has just started. I checked it and it's at normal level. How would I check the piston rings?
完成的
Of course the piston rings are around the pistons and the the engine would have to be torn down to inspect them. This usually does not happen until a mower is several years old.
完成的
添加一条评论
添加你的答案
Clif 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 51
