跳转到主内容
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
New Batteries, TI-83 will not turn on No Pixels
TI-83 has fully charged AAA bastteries. Will not turn on. No pixels. Where is the location of the neared TI Repair center located in Tucson AQrizona. Please advise as soon as possible. Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
take a look at your other post for my reply...hope this helps
完成的
添加一条评论
2个答案
最有帮助的答案
Unfortunately, TI doesn’t offer any repair centers anywhere. If your calculator is still within warranty they will replace the unit, but if it’s out of warranty then you’ll have to pay for a new one. Your problem likely has a very easy fix so there shouldn’t be any need to contact TI yet.
  1. This may be as simple as the contrast being too low. Turn the calculator ‘on’ as you normally would. Now press [2nd] then the up arrow multiple times. After a couple times of pressing [2nd] and the up arrow, the screen will appear again if the contrast was the issue.
  2. If that’s not the issue then, as jostewcrew suggested, try changing out your backup battery. There’s a guide for accomplishing that here: Texas Instruments TI-83 Plus Backup Battery Replacement
  3. If it still doesn’t turn on then there may be an issue with the screen itself. If you have the link cable that connects your calculator to your computer, install ‘TI Connect’ (Not ‘TI Connect CE’) on your computer then connect the calculator to your computer. (The port is on the bottom of the calculator and looks like a headphone jack). If your computer detects that your calculator is connected, then there’s something wrong with the screen itself. Likely the ribbon cable is degraded and needs repair. There’s a guide for fixing that on a calculator forum called Cemetech: https://www.cemetech.net/forum/viewtopic...
  4. If your computer still doesn’t detect the calculator (make sure it’s on!) then there’s a more serious hardware issue and may not be diagnosable or fixable.
Hopefully you don’t need to get past step 2 but I wanted to cover all bases just in case. Good luck!
这个答案有帮助吗?
得分 1
添加一条评论
此回答最初是针对另一个问题
@cool.aid.kid…from what i can tell, there are the batteries you changed (please ensure that they are in the proper direction) and one internal battery that you can change by opening the device. i would check this battery as well. other than that, take a look at these posts that may help:
Calculator wont turn on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cool.aid.kid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 230
