New Batteries, TI-83 will not turn on
TI-83 Plus will not turn on when new batteries have been inserted. No corossion, Batteries all at 1.54 volts. What is wrong and can it be repaired?
Unfortunately, TI doesn’t offer any repair centers anywhere. If your calculator is still within warranty they will replace the unit, but if it’s out of warranty then you’ll have to pay for a new one. Your problem likely has a very easy fix so there shouldn’t be any need to contact TI yet.
Hopefully you don’t need to get past step 2 but I wanted to cover all bases just in case. Good luck!
这个答案有帮助吗?
@cool.aid.kid…from what i can tell, there are the batteries you changed (please ensure that they are in the proper direction) and one internal battery that you can change by opening the device. i would check this battery as well. other than that, take a look at these posts that may help:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 38
总计 3,187
