跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 个问题 查看全部
gray folder with question mark - erased hard drive - nothing working
I’m not positive that I have the correct model of iMac listed. This is an older iMac that I purchased from a friend. I’m pretty sure it’s 2009 though.
I tried to erase the hard drive so that I could start with a clean computer. After erasing the HD, I tried reinstalling OS. When I chose “Reinstall” from disk utility and clicked “Continue” nothing would happen.
So I did a hard restart. That’s when the gray folder with question mark appeared. I have tried resetting the PRAM, CTL+CMD+R, Option… pretty much every suggestion I could find. Who knows what I’ve done at this point.
I’ve restarted my computer about 20 times. Unplugged it and let it sit, etc. Everything brings me back to the gray file with a question mark (except OPT on restart which gives me a plain gray screen)
This is too large of a paperweight for my small desk. PLEASE HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
To find out your exact machine and minimum and maximum operating systems, find your serial number on the bottom of the stand and input it here:
https://everymac.com/ultimate-mac-lookup...
To restore from your Time Machine backup you must have the same or higher operating system.
这个答案有帮助吗?
得分 2
添加一条评论
Maybe you wipe the HDD in the wrong format thats why its not detected. Also tried to check if the cable connection is properly connected
这个答案有帮助吗?
得分 1
1条评论:
Thank you for that suggestion. That was my problem at one point. I think I have found the solution. I connected an external drive that had a time machine backup on it.
After restarting with CTL, OPT, R … I was able to see the disk utility. I needed to connect to the internet, but couldn’t install my time machine backup since it was from my laptop & had a different version of OS.
However, I did get the option to install on the clean, wiped HD. It looks like installing. Fingers crossed.
thank you for your help!
完成的
添加一条评论
添加你的答案
Tam Eggert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 112
