跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
power button doesn't work correctrly
Hello,
I have the MacBook pro early 2015 and the battery was dead after 4 years so I decided to order a new one and change it. So I removed the old dead battery. After checking that nothing was destroyed by me I ordered a new one. After some weeks without the battery, while I was using my MacBook I spilt a little bit water to my laptop. I immediately disconnect the MagSafe and my pc was off. After that, I blow with compressed air the keyboard to dry the keys. Subsequently, I took the motherboard and clean it with alcohol (I haven’t isopropyl alcohol). Today I noticed that the power button doesn’t work unless I disconnect the MagSafe, pressed it for 1-2 seconds, plug in the MagSafe and then press the power key.
Any ideas??
Thanks in advance
Update (03/26/2020)
You can see how the power button behave
->https://youtu.be/uRdUsnvFl5o
->https://www.youtube.com/watch?v=VF0RxEDi...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
May be try to closely look with a ‘lens’ or microscope for any short/damage to the DC in board. Or replace it.
Careful: may be you can cause more damage by opening and analysing. At least it works now!!!
交换MacBook Pro 13" Retina显示器2015早期版本的MagSafe DC-in板
这个答案有帮助吗?
得分 0
2条评论:
I found that the button doesn't work at all. If you disconnect the MagSafe and reconnect it without the battery it will turn on. This is the reason that it boots.
I probed the pin five of the connector of the keyboard and pressed the power button, it hasn't resistance between the ground. Is there a probability that the only key destroyed by the water is the power button??
完成的
google for louis rossman repair in youtube. May be you can see those videos and get an idea for solving the problem!!!
完成的
添加一条评论
添加你的答案
Κωστας Λαζαριδης 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 157
