Starter wont disengage, why
I have replaced the starter on my 2000 chevy cavalier with 2.2L engine 2 times in 3 days, it works great at first but will not disengage, there is nothing wrong with the flywheel, not sure how to fix it or what to check.
Check the spacer in the nose end of the stater. If it is missing the bendix gear will extend to far into the flywheel causing it to hang in the engaged position.
这个答案有帮助吗?
When I put the starter on it did have the little sleeve but when I took it back off not even a day later it was chewed up
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 84
1条评论
I figured out the problem, the person that put the first replacement on had a wire in the wrong spot. Thanks for the help
由 Jwanna C 完成的
