跳转到主内容
加入维修社区 - 创建账户
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
LCD thermal sensor cable broken. Options?
Hello,
I just broke the LCD thermal sensor CABLE of my Late 2009 27” iMac.
Besides changing the heat sink, is there another option to consider?
Also, is there a way of checking if the port is damaged before doing anything else? Just in case.
Thank you
A.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Please post a few pictures of the damage 在已经存在的问题里加入图片.
Not sure why thing think the heat sink has any bearing here? Elbows and knees are joints but don't have direct involvement with each other.
完成的
Thank you for answering, Just put the picture online. I thought it was the name of this cable. What is the correct name, please? Thank you.
完成的
添加一条评论
2个答案
最有帮助的答案
Strip back the insulation on the wire and stick it in the receptacle.
UPDATE
I could not find the sensor without the heat sink but you can get it here with free shipping for under $8.00
https://www.ebay.com/itm/Apple-iMAC-A131...
这个答案有帮助吗?
得分 3
4条评论:
Thank your for your suggestion. Not sure if that will work because there seems to be the rest of the cable inside and I am unable to retrieve it and get the broken part in.
I thought of buying the piece of black plastic aside and breaking the other part and then follow your suggestion. But I don’t know the name of the plastic piece. Does anyone know, please?
完成的
You might be able to get a connector off of a junker heat sink which you can splice the wires. Or your other choice is to replace the heat sink assembly iMac 27" Graphics Card Heat Sink Radeon HD 4850, Apple P/Ns 661-5315 (593-1043)
完成的
See the tag on the cable? There should be a part number on it, please give us that.
完成的
@mayer - its 593-1043, I looked at my parts system ;-}
完成的
添加一条评论
Same thing here. Mine is broken right at the plug for the mainboard. Realistically if I could find the same plug off of a broken sensor, or one with the same spacing and pin size.
I'm wondering if something could be made with a couple of individual "dupont" connectors; basically I'd hot-glue them on the mainboard, and then add a second connector in-line after it for the heat-sync.
I don't want to put a lot more money into this machine, as I'm not even sure that the failure isn't in the mainboard itself (I just bought a new PSU for it). If that's the failure point I'd just sell of the rest of the internals and convert the iMac to a monitor (it's a higher resolution than the usual 27" monitors you get at the local stores).
EDIT: adding a couple pictures of the connector on the mainboard for the GPU thermal sensor.
这个答案有帮助吗?
得分 0
3条评论:
I have a couple pictures of the connector on the mainboard, but I can't figure out how to add them to a comment.
完成的
@senileotaku iFixit's software doesn't allow for pictures in comments; the closest you can come is to add them in another answer, or you could start a new question.
完成的
@senileotaku - I've converted your comment to its own answer. Go into edit mode and add in your image/s using the toolbox accessing it from the far right icon in the menu ribbon. One you add it click on it again white your insert pointer where you want to post the image ID.
完成的
添加一条评论
添加你的答案
A. J. M. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 303
