Got bubble solution in my phkne
My son got bubble solution in my phone and i didnt realize it right away. What can i do?
Hi @babycat39 ,
As you know water, (in your case bubble solution) and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion doesn’t stop until it has been cleaned away.
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents or other additives and is not as effective. If you do use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 40
