跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook won't boot after trying to installing SSD
Hello everyone,
I installed a SSD replacing the HDD in my MacBook mid 2012. After installing the SSD the PC won’t boot anymore, the LED indicator blinks once, then the fan spins for 1 second and stops. After around 10 seconds this just repeats, LED blinks, fan spins 1 second and over.
I tried putting back the HDD, but the issue is still there now :O Any advice would be appreicted.
I’ve also tried to boot without any hard drive and without the battery, but it’s all the same. When i boot without any harddrive, nothing happens at all.
Please Help :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
添加一条评论
2个答案
已选择的解决方案
I’m suspecting your HD cable has failed but I’m not sure, did the display show any image? About the screens on your Mac as it starts up
这个答案有帮助吗?
得分 2
6条评论:
There is nothing showing on the display at all. The guide you sent i followed it, im not an expert with PCs but basic replacements like this i never &&^&@@ up before this bad xD I have no idea what i could've done.
Thanks for the reply, any help is apprecited.
完成的
A fully dead system will require deeper diagnostics that what you can perform. Time to visit someone who is skilled in fixing mac systems.
完成的
@danj aight :) don't you have any possible troubleshooting I could attempt? Seems unlikely it would be worth getting this machine serviced. Any help is appreciated. After all I've build shittons of stationary pcs and worked at a phone repair shop, but this just doesn't make sense for me :)
You seem to be smart in the area, so any help troubleshooting I could attempt I would be very grateful for!
完成的
You'll need the schematics, board views & a good DVM to trace the power lines for a starter. Do you know how to read them as well as have the ability to solder SMT devices?
完成的
@danj Nah that's out of my expertise :-D It was just if you were suspecting to replace a specific part, i could try to do that :-) But thanks for trying to help me out, I appreciate it
完成的
显示更多的1条评论
添加一条评论
Just a shot but worth a try - disconnect the mag-safe. Disconnect the battery. Press and hold the power on button for ten seconds. Reconnect the battery, then the Mag-safe adapter. You should get a spontaneous reboot. This failing, take it to an independent professional.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Christian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 333
