跳转到主内容
Apple制造的一体机。iMac从2006年1月起配备Intel处理器
7455 个问题 查看全部
Display Data Connector on Logicboard broken
Hello there,
it just happened to me today. I broke the data cable connector part on my iMac 27". Is there anyway to repair it, because its actually on the logicboard itself.
I didn't know that I pulled off the display cable with its socket out of the logicboard. I saw that later when I wanted to put everything back on.
Here is a picture:
http://f.cl.ly/items/3u2S290N22090E1R0N0...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
Please post a photo of the problem again with a larger circle. It looks like you've cover up what we need to see.
完成的
any updates on this? Just did the same thing to a 27" iMac - need to look into fixing as the logic board is crazy expensive.
完成的
Helllp I have the same problem. I snapped two pins off. I wanted to sodder the pins back, but I sneezed and I cannot find them anywhere..
Anyone know a way I could improvise pins from somewhere else?
Regards
完成的
What ever happen? I have the same problem and Symutech says it's un reparible.
完成的
添加一条评论
2个答案
已选择的解决方案
Oh dear. . . lol
It appears as though you've not only removed the connector, but along with it, one of the pins.
A patient and creative solderer with skill could possibly fix it, but it would be tricky.
In cases like these, I believe they're fixable. I've done a few repairs with broken connectors on Apple logic boards myself.
There's only so much we could write to you on the Internet. Haha. If I had it right here, I'd start soldering away! You've just gotta find an engineer who's willing to take a look at it. :)
这个答案有帮助吗?
得分 2
7条评论:
Soldering things such as that are best done under a stereo microscope and a soldering iron with a 1/64" conical tip.
完成的
Absolutely!!! :) Well said.
完成的
hello there,
do you guys have any pictures of your work?
do i have to solder everything pin by pin or just pin everything at once?
cheers
完成的
I would use solder paste instead of solder wire for this. Are you going to try to repair this socket or install another one? Have you previously soldered under a stereo microscope before?
完成的
I would find someone who can do this for me. I never soldered anytime before.
I'm going to replace the socket, i bought a new socket from digikey:
http://search.digikey.com/scripts/DkSear...
What do you mean by solder paste? The pins on the socket have to be carefully soldered to the Logicboard right, i mean every pin piece by piece? I cant place just a paste by one stripe right?
Sorry for my bad english. I hope you understand me.
Cheers from Germany
完成的
显示更多的2条评论
添加一条评论
the quality of these pins is very poor, the same problem happen to me so i bought a proper lcd conecter from ebay
www.ebay.co.uk/itm/APPLE-imac-27-inch-internal-lcd-connector-FI-X30SSL-HF-/180750151856?pt=UK_Computing_Apple_Mac_Accessories&hash=item2a158c70b0#ht_1081wt_1413
and get rid of all the old pins and solder the new conecter with abetter quality pins
good luck
Omar
这个答案有帮助吗?
得分 1
1条评论:
Omar, can you provide more infer about how you used the new connector from eBay? I lost most of the connecting pins on the logic board, so I'm interested in learning more about how you used a different connector that doesn't require those delicate pins. The actual internal lcd cable plugs into the part that you bought, right?
Thanks,
Joe.
完成的
添加一条评论
添加你的答案
Atilla Taskiran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 7,505
