跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
775 个问题 查看全部
(MacBook Pro 15" Retina Screen, Mid 2015) Display Issues
Screen flickers and has vertical lines on right side of display. Problem started out small and intermittent for two days and suddenly got worse today. Display issue does not show up on external monitor. I have already tried software fixes like resetting PRAM so problem is most likely hardware. Out of warranty and don’t want to get overcharged at local apple certified repair shop, hoping to get a clue to what the problem is before taking it in. Any help appreciated!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
最有帮助的答案
Sadly your internal display is bad. You’ll need to replace it to fix this. Here’s the gunned you’ll need to follow: 2015年中视网膜屏macbook pro显示器组件更换
Now the shoe drops! These displays go for big bucks! This is because many had bad anti-defective coatings. A new one goes for over $600 !! A used one can be half of that if you can find one 15” Retina MacBook Pro Display Assembly, Apple P/N: 661-02532
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jessica Herndon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 54
总计 2,961
