跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Tristartester dock fail, but the phone charges.
A colleague uses a tristar tester (small blue box) and brought a phone that gave a dock FAIL when using the tristar tester. I have no experience with this device. The phone charges fine and I have 3.7V running on BATT_VCC. Dock resistance is the same as ZXW.
What should I check next? Does anyone have experience with the tester? I don’t wanna just change the tristar and hope the problem goes away.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Does the battery hold its charge and doesn’t run empty fast?
完成的
gonna test this today
完成的
添加一条评论
3个答案
已选择的解决方案
The Tristar Tester does give false positives so take a step back and try to determine what the original problem was and why the other shop used a Tristar tester in the first place.
Often times, we can get fooled by other people’s (or tools) troubleshooting conclusion. Always ask for the original problem, do the troubleshooting yourself and then see if that matches the conclusion of the customer or referring shop. Don’t forget, they are coming to see you because YOU are the expert, not them.
这个答案有帮助吗?
得分 4
添加一条评论
I have used this tester for a while now, as Minho stated sometimes they do give false positives. Dock failed doesn’t mean a faulty Tristar it is implying it has picked up an open line. I have had this happen with some aftermarket dock connectors or when I have connected the tester upside down as it is not reversible.
Some things you should know about using this tester.
·         Make sure it is connected the right way.
·         You need to have a good connection.
·         It will show dock failed on some aftermarket dock connectors even though the dock is fine.
·         This tester is unable to verify you have a good dock connector it only checks for open lines.
·         These testers only tests 8 of about 25 lines on the Tristar, I have come across the 1V8 reset line being faulty but the tester displayed “passed” as it doesn’t check this line.
·         If it shows fail it doesn’t automatically mean a bad Tristar I usually check if multiple lines have failed before replacing the IC if only one or two lines have failed a would try another dock first.
这个答案有帮助吗?
得分 3
4条评论:
Chris, this is a great update! Based on your experience, do you recommend this tool as they are quite expensive? I've always seen this tool as more oriented towards non micro-soldering shops.
完成的
I have a tristar tester if you mean the little green pcb one. I never use it anyway.
完成的
@benjamen50 What the OP and Chris are referring to are the blue box testers like this one.
完成的
@refectio I don’t think it is a necessity Minho I only use it because it is there and if it broke I wouldn’t purchase another one unless it could check all the lines under Tristar. There have been more than one occasion when I have connected it in front of customers and told them there Tristar is fine and it’s probably the battery or dock and then having to bill them more because it was in fact a faulty Tristar. At the end of the day it doesn’t take long to change Tristar and it can be ruled out and you can move on without something in the back of your mind telling you “maybe I should have changed Tristar first”. Another thing I came across once was with the iPhone XR it showed Hydra as “Failed” when actually it was Tigris which I would have seen if I had looked at it instead of believing the Tristar tester and replacing Hydra.
完成的
添加一条评论
Device wasn’t charging according to the customer. so my colleague checked with the tristartester. It said “check battery pressure” and “USB connection “. He then replaced the battery and charging dock  After that it gave the “dock fail” I tried another dock and battery and got the same message.
I’ll check when I get the store if it is still working.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
KWH 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 13
总计 620
