跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
Unable to activate iPhone 7
Hi, Ive been given an iphone 7 and, since trying to start a fresh with the phone, im presented with a “unable to activate” error message.
I have tried entering into recovery mode to update or restore, both unsuccessful.
I then went into the Apple store and was told it probably because ive a aftermarket screen fitted and sent on my way?
Any ideas ?
Regards,
Michael
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
For some reason, ive switched it on today and its managed to update to 13.3.1, which it wouldnt do before.
Not sure this is of any relevance , but thought id mention anyway.
完成的
添加一条评论
3个答案
已选择的解决方案
This will have nothing to do with the screen. It is more likely a baseband CPU problem created from an audio IC repair. Was the phone able to connect to a cellular network before you restored it?
这个答案有帮助吗?
得分 3
1条评论:
I didnt think it would be the screen either and had the feeling i was being fobbed off.
Yes, the phone was working fine until i erased things and updated it.
完成的
添加一条评论
At the HELLO screen when you press the circle with the i, does it show your imei nr# ?
这个答案有帮助吗?
得分 1
3条评论:
Hi, no it doesnt give me the IMEI number. It gives me one number. I dont have the phone to hand and cant think which number this is?
完成的
Because there is no imei nr i think that your baseband ic is faulty.
完成的
Sounds like its above my skills to fix then .
完成的
添加一条评论
My iPhone7 needs email to icloud and password, but the owner has forgotten
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Michael 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 7
总计 387
