跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE not charge after battery repair
My friend replaced his iPhone SE’s battery recently.
He can’t charge it after replaced the battery, the phone says its charging but the percentage stays the same. He found if he remove the pentalobe screw the phone will charge normally. Then he used the phone without pentalobe screw for weeks without problem.
Today he got a new phone case which will holds the screens a little bit and after put it on the phone is not charge again, he found if he press down the bottom left corner of the screen the phone will not charge.
I have completely no idea what will cause this. Any ideas on what to do next or what the problem might be?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try to clean the dockconnector with a tooth pick, there can be dust inside.
这个答案有帮助吗?
得分 0
1条评论:
Sorry, this doesn't work.
完成的
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 52
