跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Mac won't turn back on after it dies from low battery
My Macbook Pro 13” Mid 2012 original battery works great (except for the 1 flaw expanded upon below). System information shows the Health condition as “Normal” — I would give the specific cycle count and capacity information, but my computer is currently dead.
HERE IS MY ISSUE:
If my computer falls to 1% and automatically goes to sleep, I am unable to turn it back on. When I plug in the MagSafe charger, the light stays bright green and never changes to Amber. If I plug in before the shutdown, it immediately goes to amber and has no issues charging to 100%
I have opened the back panel to disconnect the battery, drained the caps, and reconnected the battery. This fixed the issue the first 2 times I tried it but it no longer works.
I have also tried the SMC reset more than once.
The most consistent solution seems to be leaving the MagSafe adapter unplugged for 16-24 hours with the battery still attached. After waiting a day and connecting the charger my computer will turn on and the MagSafe will go orange ~75% of the time. The other 25% of the time the computer won’t turn on and the adapter just stays green.
Not sure if this makes a difference, but when I press the small round battery indicator button, one of the indicator lights flashes green about 10 times. The flashing occurs in the same manner whether or not the MagSafe adapter is attached.
P.S. — Please don’t respond with “well don’t ever let your computer fall below 1%”. Obviously I try to do this, but I don’t sit at a desk all day and I’m not perfect.
BOTTOM LINE: I am not in a position where I can wait a full day to get my computer back on. Is there any way to resolve this? Do I need a new battery (seems silly since everything else about it works great). Is there a different component that needs to be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If I need a new battery it won’t be a big deal. It’s an easy repair. But I have doubts a new battery will fix my issue, since the health condition of my battery is “normal” and it holds a long lasting charge. But please let me know if anyone thinks a new battery may solve my issue.
完成的
添加一条评论
1个答案
最有帮助的答案
Do an additional step. Unplug the battery and the mag-safe adapter, the Press and Hold the power on button for ten seconds. Now reconnect the battery then plug in the mag-safe and you should get a spontaneous reboot.
这个答案有帮助吗?
得分 2
1条评论:
@mayer this unfortunately did not work. Disconnecting the battery and adapter, holding power for 10 seconds and then reattaching battery and adapter yielded the same result. Adapter is still glowing solid green only and the computer won’t turn on. I do appreciate the response so thank you for that.
完成的
添加一条评论
添加你的答案
DonDior16 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 35
总计 1,806
