跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
MBP wont boot, black screen, lights working, mag strip green.
Okay folks, new here. Hello! I have a 2011 MBP 15” display. It shut off randomly now I cant get the sucker to boot.
The charger lights up green (full battery)
Push power button the fans click on for like 5 seconds
Front right hand corner white light comes on for 5 seconds then shuts off.
I dont get any chimes or bings.
I have tried every single button combo PRAM reset, Ive reseated the RAM now.
Tried the tapping the corner trick no dice.
Nothing on the display whatsoever.
Any gurus on here can point me in the right direction to start for possible fix?
Greatly Appreciated!
Ryan
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The dual graphics GPU is a well known issue on this model.
You will probably have to install this on another Mac by pulling your hard drive and hooking it up to another using an USB to SATA adapter.
I’ve saved about twenty 2011 15” MBP using this gem, it’s also free ;-)
To turn off the dual graphics capability of the GPU, install gfxCardStatus for Mac
Download  https://gfx.io
This will disable GPU switching and force the MacBook Pro to use the higher powered discrete graphics card rather than the integrated GPU.
  1. Go to the  Apple menu and choose “System Preferences” and then go to “Energy” control panel
  2. Uncheck the box next to “Automatic graphics switching”
  3. Note the text which states this may decrease battery life on the MacBook Pro “When automatic switching is disabled, your computer will always use high-performance graphics. This may decrease battery life.” – if you are not OK with that do not disable this option
  4. Close out of System Preferences
  5. You can always return to the Energy preference panel to re-enable the GPU switching feature if desired.
  6. For MacBook Pro users who want to manually control their GPU use, you can use a third party tool like GFXCardStatus which has been around for quite some time and still works on most modern MacBook Pro models as well.
  7. https://gfx.io/switching.html
这个答案有帮助吗?
得分 2
1条评论:
Noted! I will give this a try thank you very much for your detailed answer! I'm excited to see if this is the answer!
完成的
添加一条评论
添加你的答案
Ryan Gillespie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 124
