I could not find your model. Check the fan first but when my central air condition pipes started freezing, it was low on freon or R22.
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
Hi @wildwest1 ,
Please verify the model number of the refrigerator as the number you supplied produces no results when searching online for schematics or parts etc?
由 jayeff 完成的
PLHS237ZDB - Purchased new in 2004
由 bert 完成的
