跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
Screen lifting after repair
I had a screen replace on my iPad Air 2 and I have had to return three times because the screen lifts from the body.i was told they use a liquid glue and it must be something I’m doing.has anyone else had the same issue and is there a fix as it’s getting expensive having to return it to the repair place.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You shouldn’t be paying for ‘screen lifting’ issue as the onus is primarily on the repair shop, it was either a bent chassis which they neglected to straighten out, or they used a cheap adhesive that usually is the culprit for weak adhesion.
I’d argue for a free warranty repair or at least refund of whatever price you paid for repeated work.
这个答案有帮助吗?
得分 2
添加一条评论
My iPad Pro does this as well, because of a bend. Make sure to your iPad isn’t bent.
这个答案有帮助吗?
得分 0
1条评论:
Going to wait till I get my hands on a set of feeler gauges and check it properly.thanks for the input
完成的
添加一条评论
添加你的答案
Caleb Crone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 174
