跳转到主内容
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 个问题 查看全部
sprays during rinse cycle
i have a roper washing machine rtw4640yq0. when i wash clothes during the wash cycle the tub fills with water and washes fine, but when n it goes into rinse cycle the tub does not fill with water it sprays the water while draining and the tub does not fill with water. is the tub suppose to fill with water during the rinse cycle or does it just spray water while draining? thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The newer washer won’t fill up for a rince, they spray while spinning the clothes. You should have a 2nd rinse option or similar to get a full rinse. The owners manual will explain the cycles and operation. Good information in the owners manual.
这个答案有帮助吗?
得分 3
1条评论:
Hello LadyTech. Question you might know. Have Kenmore model # 11020922990. I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? It used to spray more/longer before it goes to the "spin" cycle? Owners manual has no info; Whirlpool doesn't know the schematics, or care. Your thoughts?
Thanks.
完成的
添加一条评论
最有帮助的答案
Sounds like it’s working as designed to me.
这个答案有帮助吗?
得分 3
2条评论:
Question sir: I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? I thought that it used to spray more/longer before it goes to the "spin" cycle? Changed the water inlet valve about 6 years ago, but do you think it could be an issue? Your thoughts?
Thanks.
完成的
Yea. My SpeedQueen fills, spins, drains and when almost drained sprays for about 30 seconds and then completes the spin cycle.
完成的
添加一条评论
添加你的答案
greg 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 39
总计 864
