not set brightness LCD
Hi guys
I changed the LCD only. The brightness setting does not work.
only ON or OFF, no brightness adjustment.
Do you know where the error is?
I’m thinking the cable may have been damaged. Multiple pins carry the backlight power. Otherwise the logic board backlight control has an issue.
Why did you replace the display? If this was a liquid damaged system the connectors or cable could be corroded as well.
Take a few pics of the connector and cable ends so we can see what they look like 在已经存在的问题里加入图片
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 43
2条评论
Can you give us where you bought the display as well as the Apple P/N for it.
由 Dan 完成的
https://www.replacebase.co.uk/apple-macb...
由 Tomas Unger 完成的
