跳转到主内容
1.86GHz or 2.13GHz Processor, 128GB or 256GB Flash Storage
not set brightness LCD
Hi guys
I changed the LCD only. The brightness setting does not work.
only ON or OFF, no brightness adjustment.
Do you know where the error is?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you give us where you bought the display as well as the Apple P/N for it.
完成的
添加一条评论
1个答案
最有帮助的答案
I’m thinking the cable may have been damaged. Multiple pins carry the backlight power. Otherwise the logic board backlight control has an issue.
Why did you replace the display? If this was a liquid damaged system the connectors or cable could be corroded as well.
Take a few pics of the connector and cable ends so we can see what they look like 在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tomas Unger 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 108
