跳转到主内容
Fourth generation of CDMA iPad 4. Available in 16, 32, or 64 GB models. Model Number A1460.
20 个问题 查看全部
No touch after digitizer replacement
I was brought an iPad 4 CDMA with a broken display. I ordered a replacement and when it arrived I installed it.
Everything went good with the install but there was no touch. I tried disconnecting and connecting it a few times and it did not help. I then hooked up the original broken display and everything worked so I called iFixit and they sent out a replacement.
When that one showed up I installed it and the same thing happened, no touch but the original display works.
There has to be an explanation for this, right?
What am I missing?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I don’t know what I did different, but I got the display to work.
Thank you for the replies
完成的
添加一条评论
3个答案
最有帮助的答案
I went through at least 4 digitizers to get one that worked properly on an iPad 5. The bad units partially worked — they had dead spots on the touchscreen. Never saw one be completely dead, but I suggest trying again. Make sure you’re getting the correct generation/model digitizer.
这个答案有帮助吗?
得分 1
添加一条评论
I tried pretty much the whole display on both of them and nothing.
The home button that came with both of them does work.
I’ve double checked the model number, so I don’t think that I ordered the wrong part.
这个答案有帮助吗?
得分 0
添加一条评论
Another possibility is that the flex connector is getting dislodged during re-assembly. When you pull up the digitizer check for damage to the flex cable. If it’s ok, then re-seat the cable and test with the unit open to see if you get any response.
I haven’t done gen 4, but on gen 5 the flex cable had to be folded just right for it to fit in without damaging it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sunruh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 41
