跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
MacBook Won't Recognize SSD
I recently was given a MacBook Pro that had a ram issue. Once I figured out it had a bad ram stick, and replaced it, it gave me a flashing folder error. On further inspection using a SATA to USB adapter, I found that macOS had been installed and used on this machine, on the SSD at one point. I have formatted the drive and tried to install macOS on it with Internet Recovery mode and a High Sierra bootable USB drive, but neither disk utility or terminal will recognize the SSD.
Update (03/01/2020)
So I installed the new hard drive cable, and the ssd shows up and is able to be formatted but… when I install MacOS on it. I get a no entry sign. I have tried installing MacOS from a USB drive on High Sierra with APFS format and from internet recovery with Yosemite on MacOS Journaled. Both do the same thing. Something else to note is that it tells me to “reinstall” macOS. But no OS is on the drive after formatted.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
Formatting a drive wipes any data (or in your case the OS) off. You need install the system from your external USB source.
完成的
@mayer Yes, that is what I did
完成的
Logan this was in response to your statement that no OS was on the drive after formatting.
完成的
@mayer Yes, the no OS is showing after I format and then install MacOS after the format
完成的
The only thing I can see here iOS that Yosemite will not install on an APFS formatted drive. I'd try downloading a fresh copy of Mojave and see if it will install.
完成的
显示更多的1条评论
添加一条评论
1个答案
You either have a bad SSD or the HD SATA cable is bad or damaged.
I’m suspecting the HD cable is bad and will need replacement. Here’s the needed part MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable a common issue is the rough aluminum case damages the cable so you want to place a strip of electricians tape on the uppercase were the cable crosses Your Hard Drive Cable Is A Ticking Time Bomb. The second issue is damaging the cable in the process of putting it in. Often I find people make a hard crease where the cable needs to be routed around a bend. You don’t want hard bends as that damages the thin foil wires in the ribbon cable instead you want a nice arc. To help in forming the arc I use an old BIC pen ink straw using it as a form brake. Bending the cable around the radius as needed.
You’ll need to reformat the drive and install a fresh copy of macOS as you want to make sure there aren’t any corruptions.
This cable connects a SATA I, SATA II, or SATA III hard drive to the logic board.图片
产品
$34.99
这个答案有帮助吗?
得分 0
3条评论:
Thanks Dan. Just updated with a new issue.
完成的
Sounds like you hadn't installed the proper OS onto the SSD yet.
About the screens on your Mac as it starts up
Mac startup key combinations
完成的
@Logan Davis -
Referencing the 'Mac startup key combinations' link above
When you restart your system press the Option key to enter into the startup disk menu, do you see your SSD listed? If you do using the arrow keys make sure to select it and let the system finish booting. Where you able to get to your desktop?
完成的
添加一条评论
添加你的答案
Logan Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 13
总计 107
