跳转到主内容
Repair guides and support for the 5th generation Honda Civic, first released in late 1991.
52 个问题 查看全部
Radiator fan not turning on?
Hey guys I think I have a more complex problem or I have over analyzed my situation with my 1992 Honda Civic 4 Cylinders 1.5L MFI SOHC
Car Overheats after about 5 to 10 minutes of driving. Radiator fan never engages to turn on, I also noticed it takes the coolant but the radiator fan still does not turn on. Checked the fan switch by bridging the current and fan turns on.
I replaced following:
cooling fan relay
temp sensor
fan switch
thermstat
I checked the other fuses underneath the hood and they were all good. Not really sure where to go from here. What are your thoughts
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论:
Alejandro Garcia hat is the exact year, engine size and model for your Civic? That way we can chase the wiring and hopefully get you a good answer.
完成的
1992 Honda Civic 4 Cylinders 1.5L MFI SOHC @oldturkey03
完成的
添加一条评论
1个答案
check the pigtail on the thermo Switch next to the to the Thermostat housing for loose wires
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alejandro Garcia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 640
