跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
Spilled tea on my MacBook, should I replace battery?
So I accidentally spilled tea on my macbook which prompted it to shut down. When I was cleaning the inside for battery stains, I noticed that unusual gel-like substances formed around this particular region.
I think the battery or connector is damaged. I’m able to use my laptop, but it relies completely on a charger now. Initially the inside looked like this:
My macbook had shells and keyboard covers at the time, which probably reduced the damage. Should I replace my battery?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Batteries do not like liquid. Change it out when you clean the board so you know there won’t be any battery problems. It already looks like the BMS is corroded too.
这个答案有帮助吗?
得分 1
8条评论:
I don't have a battery yet but I'll order one, so in the meantime I guess I'll remove the battery. Could you identify the BMS for me? Is that a separate issue that I should order separate parts to fix?
完成的
@djli - The BMS are the chips on the batteries logic board.
完成的
@danj I can already tell the electrolysis corrosion started from the photo. Game over in terms of not needing a battery :-(.
完成的
@danj Will a battery replacement fix the issue? I backed up the mac and took out the battery, but now it’s unusably slow.
完成的
@djli That could also be an SMC issue - hopefully it's an easy fix. Unless you had an EFI lock badly removed, it's not going to be an Intel ME issue. Try the battery first; the damage is done.
Did you use the stock 60W or an 85W adapter (upgrade)? These machines throttle without a battery unless you use the 85W adapter. I keep an Apple 85W on hand because it's nice to have for throttling hardware like this.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
David 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 308
