跳转到主内容
发售于2017年11月3日。型号为 A1865, A1901。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供银色和深空灰色。(读音与“iPhone 10”相同)
1199 个问题 查看全部
My screen keeps glitching without dropping iPhone
So I was on my phone watching Tik tok when a bright green appeared in the upper right corner when the LTE and battery is. I was shocked when I saw it appear so I tried turning my phone off and then back on. It was blank until it turned back on and the entire screen was glitching and everytime my screen would dim from being on for so long it glitches like crazy until I click on it again. Sometimes when I try and unlock it, it won’t let me open my phone for a good minute, sometimes I get lucky and it allows me to unlock my phone but I wondered if you could help me…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Also when I turn my brightness down all the way it glitches like crazy
完成的
添加一条评论
2个答案
Are you sure you didn’t drop it? These type of screens get this after a bad drop, I would recommend a digitizer replacement. Even with out it dropping this can happen.
这个答案有帮助吗?
得分 0
2条评论:
I might’ve dropped it says recently but when it started I was on my phone that morning . Do you think I can get it digitized at Best Buy? Apple?
完成的
You can replace at Apple but it’s expensive. Geek squad is bad. Try a local shop or you can do it yourself! It’s super easy for a beginners.
完成的
添加一条评论
This happened to my phone after a bad drop, so for sure this is the reason. I have a friend that repairs electronics and he fixed it for me, so I didn't have to pay a lot of money. I used to daily upload content on TikTok so when I dropped it I was so sad I won't be able to do this in the next few days. I care a lot about my account and regularly get free followers from tiktokfollowing.com to improve it and daily content is also a part of my strategy. Well, the damage wasn't that bad, so I got it back in two days, but now, I have a back up just in case.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Camryn Strecker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 94
