跳转到主内容
发布于2011年7月21日。Core i5或Core i7处理器。雷电(Thunderbolt)接口。本机也用于Mac mini Server配置。
Server with only Apple SSD then add a second spinning drive?
If I get the Mini Lion Server with just Apple's SSD installed can I just add the second hard disk? Are the cables and or connections already there? Do I need a kit? Is the one for the non-server mini what I need?
Regards,
John
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
A server version of the Mac Mini already has all the necessary cables, as well as two drives. If you're asking if you need to purchase another hard drive, the answer is no, unless you want to upgrade the HDD already there. Our dual drive kit is for non-server models, which only have one hard drive (specifically, the top one). Our kit is an alternative to purchasing a server model, because you can install any second hard drive you wish, whereas the server model from Apple comes with both drives already.
这个答案有帮助吗?
得分 2
1条评论:
you can then install a HD SSD in a mac mini basic server?
you would say yes
Thanks
*sorry for english
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,113
