跳转到主内容
The most popular option to light large areas of buildings. They come in a variety of connection types and power ratings.
22 个问题 查看全部
4 ft fluorescent lights inside work outside don't.
I recently obtained 25 / 4 bulb lights. They came out of a building that is being remodeled. I hooked a couple up in my shop only to find out that the 2 inside bulbs work and the 2 outside don't. I tested every one and the same thing on every one. I'm very confident that one ballast on all of them isn't bad. Is it the way they are wired ?. They have magnetic ballast MB 2x40/120 RS in them. I'm not very knowledgeable in this field. All advice we be appreciated. Thank you in advance. P.s I thought each side worked off a ballast.not the center 2 and outside 2
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@jamesray1370 that is odd. the MB 2x40/120 RS ballast is a 2 lamp ballast. Add some good pictures of the wiring from those lamps with your question. Something not quite right here ;>)
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Henson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 357
