跳转到主内容
Bluetooth, google play compatible, 8 GB of storage available.
18 个问题 查看全部
Continuous bootloop Android phone
My Android Rebel 4 is stuck in continuous bootloop. How do I fix this
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi @nettie162774 ,
Try removing the battery then wait for 5 minutes before placing it back in and then try to turn on the phone.
这个答案有帮助吗?
得分 0
1条评论:
Thanks for the suggestion.
完成的
添加一条评论
LG is known to have bootloop issues that are related to bad boards. Sadly it’s usually not something you can fix with a battery removal. The board needs to be reworked to run for data recovery and it needs to be replaced. Been there with my G4 and it’s still been my last LG to this day. Supposedly the phones like the G6 and subsequent models from that point are okay, but the damage is done - too little, too late. They seem to go bad within ~2 years from what I’m aware of.
In an answer to my own question on this exact same issue. It isn’t easy, so make sure you can do it because you usually only have one chance and a few reruns and it’s over. Refer to this question: How do I get the phone working for data recovery?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lynette Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 216
