Constant Attaching/Detaching of Keyboard and tried obvious solutions
Recently I have come upon an issue where the keyboard keeps attaching and detaching intermittently.
I am no stranger to this issue over my 2 years of using this computer. Usually I have to just clean the connectors and it works again. If that doesn’t solve the problem right there, a hard reset (power + volume up held for 30 seconds) usually resolves this. Also I can tell it’s the connectors because moving the laptop around or adjusting the screen pivot usually triggers the issue reliably before I clean it.
However this time I am stumped. I have cleaned the connectors (both the keyboard and computer side) thoroughly with rubbing alcohol. The screen can attach fine no problem and everything is working. Moving the monitor around, shaking the laptop, gentle taps, don’t trigger any upset to the connection. However the computer is now attaching and detaching constantly regardless of the conditions (moving or not moving).
The timing of this can be as fast as 10 seconds apart and as slow as 5 minutes apart between attaching/detaching interruptions. When it is ‘detached’ on many occasions the keyboard and mouse still work. Other times it actually interrupts their functionality.
Things I tried:
- hard reset multiple times
- cleaning thoroughly the connectors
- making sure windows is updated
- making sure drivers are updated
Only thing I haven’t done yet is a full hard reset. Looking to get my files/programs in order to do a full wipe and hope for the best.
The computer was working perfectly until after one quick site visit where I reattached the keyboard and used it as a bulky tablet. Right after I put it back into it’s original laptop form, the issue popped up. I keep thinking it’s physical but I am not sure what the cause could be. My highest suspicion revolves around the cable that runs along the hinge of the keyboard, connecting it to the pins (only a suspicion, I am not sure as tilting the monitor doesn’t cause any detaching issues directly). But I am at a loss as to how to check or deal with that.
Sorry for the long description but if there are any thoughts I can try I would love to hear them. I am out of warranty so dealing with Microsoft is a no go.
Thank you!
1条评论
Guys I have the same issue can anyone help me plzz @Ifixit
由 HYDRA 完成的
