跳转到主内容
加入维修社区 - 创建账户
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
3gs screen won't turn on at all
hi everyone, so my iphone touch screen wasnt working unless i apply some pressure on the top of the screen, so i opened the iphone to see if there was any loose connections, there was a loose connection, when i was reassembling the phone the number 1 connector snapped out and the screen turned off, then i reconnected it and it worked again, then when i was reassembling it, it snapped out again, but this time i cldnt make it work again, i tried hard resetting and disconecting the board from the battery, but with no luck, it can connect to itunes i can hear sounds the vibrate button works, but it doesnt show as a camera on the computer, what shld i do plz help ty in advance :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Try taking board out for an hour. Then reassemble. Make sure all display (1,2 &3) connections are clean/undamaged and secure( I know you said you took board off battery.. I think it's a temperature thing for th reset) try a restore.. The reset... Home and power usually works if it doesn't then I'd buy a new LCD.
这个答案有帮助吗?
得分 1
1条评论:
Keep iPhone 3GS OFF when doing repairs or you risk damaging the LCD display or Logic Board Controllers of LCD display.
完成的
添加一条评论
添加你的答案
Ram015 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,498
